Ordering 265/75/16 Duratracs? Pics?
GA02RUNNER
I know this is probably a past discussion at one time but im about to get a set of 265/75/16 Duratracs for my Runner, right now it has stock wheels and suspension. Anybody have pics of their Runner with 265/75's either stock or small lift? Planning on 1.25" wheel spacers and a lift following tires but I don't want a full 3" lift but also dont want a body lift. Suggestions and pics appreciated
I ran a set of 265/75s for about 60k and didn't have any problems. No lift. A small amount of trimming might be needed if you wheel a lot, but otherwise just put them on and work out a lift later.
I'll keep an eye out for your pics ghostring. Hey Drew, were you running wheel spacers when you had your 265? Id like to run 285 but its my dd and living in GA I wont be doing any hard wheeling. And with 265 I dont know if it would look right with a full 3" of lift thats why im searching for the smaller alternative
Not duratracs but here is my truck stock on mud 265's, 3" lift with 265's then 33's, 1.5" bl with the 3" lift settled in.
That's about my stance right now. It's really not a bad set-up at all.
I get a light "brrrp" occasionally backing out of my inclined driveway, Ltd flare is likely the culprit.
I'm curious if that will get worse with spacers - even with the additional lift.
range_zpsab949c6a.jpg~original
I'd almost forgo my planned lift, but the factory suspension is roasted - so I figure a little extra
clearance will come in handy for any future ideas (i.e. 285 or 255) and extra load capacity.
Just got them on...
Stock 1998 Suspension w/ ~193K. Not sure if it is sagging or not but it does have a match full spare. Like you I'm also planning on just a 1-2" lift in the future.
Ok seeing 265 verse 285 im now questioning if 265 is truly what I want. 285 sure does make them look a lot more beefy. Ahh decisions, 285's means mandatory lift. Thanks Woodro and Jayrolla!
patnewton
