Overheating Problem?
marley4runner
Have a '88 4runner that randomly overheated I think while driving it the other day. Typical steam started coming out ront left of the hood and when I pulled over and popped the hood the coolant was all over the inside, mostly down towards the front driver's side wheel well. In looking for a leak however I couldn't find one but the coolant was drained. From the spraying it looked to be a tiny hole as it spray all over the place. The car started back up no problem but I didn't drive it and opted for the tow home. Any suggestions? Much appreciated.
Kyle
Flush and fill, then go to a shop for a cooling system pressure test if you don't have the tools. And I agree with 97-4xFunner, just ditch that thermostat and replace with an OEM or other reliable Tstat.
Do check your radiator. I had several pin hole leaks in mine. (which I discovered after I blew the headgasket) Apparently it's common in the 4runners.
Just had the 3 core all brass/copper radiator on the '91 boiled/wroughted out, totally cleaned and and painted for $70.00. My guy said it's a saver and should be good for at least another four years (with proper maintenance and fluids, of course)........
it honestly might not sound like much, but if you got a leak in your radiator then, buy the bars stop leak at autozone. That **** works amazing.
You're correct, it is amazing stuff. But no one I know ever uses it unless it's either a dire emergency, or the vehicle is being sold within the next two weeks. Something about putting solids in a system designed for fluid and all.........:D
Thank You
Thank you to everyone for your suggestions, I guess I'll begin with the thermostat and work from there, hopefully it's not the radiator but the way the coolant sprayed out a pin hole leak sounds like it might be a logical guess. But I really appreciate everyone's recommendations.
even if it is the radiator its not such a big deal they only cost 100 bucks and anyone can pull it out and put it in.
