Owner's review of HID bulbs replacement for 2014+
Post beam pattern pics please. I'm seriously considering doing this hid upgrade. On the headlights and fog lights. I did the H9 mod and its brighter but it's still not enough. I'm running Osram Nightbreakers on my Evo and those are seriously bright, like a cone of daylight in front of the car.
What is the bulb in the fog Lights? Those are seriously weak Sauce!
The fogs below match the 5000K HID's perfectly in color!
Here is an excellent fog light upgrade!
Morimoto XB LED Fog Lights (Type T)
Here is the link for guides and installs from some of us!
http://www.toyota-4runner.org/5th-gen-t4rs/172771-direct-replacement-led-fog-light-assemblies-2014-other-5th-gens.html
Ok people keep installing these, Im however not very smart and im stuck with my Morimoto install a little bit:
Can someone tell me where each end of the kit goes? Thank you:sadwave:
Were you able to figure it out?
Q1 - Relay harness on mine was mounted in front of AIP on the cross bar that is covered by the plastic panel. "Wires are hidden underneath too
Q2 - Ballast were mounted to the sides of the engine bay closest to the headlight assembly " Left of AIP and Side of the Battery area"
Q3 - That plug will connect to your existing H11 in the headlight assembly to power the relay. It doesn't lock all the way when i did mine but a few zip ties did the trick to lock it up.
If you need pics, let me know!
Thank you for your help!!! I will get back to it in a ciuple of days. Can you please looks at Q.A and Q.B and clarify which one goes where? :bluejump::bluejump:
QB is a pass through for the stock h11 connector to the harness QA. Since the location of my harness was close, i removed the 9006 extension on QA and went straight to QB.
The 2nd bulb will have a connection similar to the other one. That will not be used and can be disassembled and pulled out for spare parts as only one stock connection is needed to power the relay switch.
We're you able to install without pulling headlight out? Looks to be very tight fit. Can you retain the back cap too? Looks like hid bulb may not have enough space.
You have to drill a small hole in the cap, and you shouldn't have to remove the headlight at all.
It looks as if you can remove the stock wiring completely through the rubber grommet at the bottom of the housing. I think when I receive my HID kit I will attempt to do it that way. Will try to remove the bumper to get a better look.
I found a repair mechanic manuals for the 2010 T4R, hopefully the bolt layout is the same for the front bumper.
My hid's are fed through the bottom of the housing, I did not drill through the cap. Nothing was drilled through, my hid kit could be removed without any trace of being installed.
This is what is preventing me from doing the HID conversion. I don't want to drill through the cap as previously I've had condensation issues.
On a 14+, do you have access to the bottom of the housing without removing the bumper/headlight housing?
Pics would be great. :)
X2...I am wondering the same thing.
If you feel under the corner of the assembly near the fender you will feel a grommet with a harness going through. Can't miss it, its probably an 1 inch grommet.
Driving home from an overloading trip...snapped a couple of my HID output. Figured this might be as if not more helpful than another set of photos facing a garage or a wall.
TRS 35w - Xb35- 5500k
I'm running an old pair of DDM Tuning slim ballasts I had laying around with some 4300K bulbs I got off Amazon. Almost 1 year and they've been just fine. Light output is good and cutoff is adequate. Friends who don't know any better think it looks OEM. And I've NEVER ONCE been flashed by oncoming traffic or felt I was glaring at anyone. I've even looked at it head on myself from a ways out. Looks just like any other car with HIDs no matter what the "Purist" guys say on here.
IMG_2343.jpg~original
You can see the hole in the bottom.
IMG_2342.jpg~original
Wiring routed...hid decently well. I purchased adapters that plug into my headlight plug directly to the ballast. I had the relay setup on my tacoma and the left would fire one second faster than the right and it irked me to death. These fire every time in sync with super fast warmup.
IMG_2341.jpg~original
Ballast tucked between the air pump and headlight.
youngrk
