P0031 oxygen sensor location
ttn6485
Guys, 4runner, 2004, V8, sport, got a code P0031, o2 sensor, bank 1 sensor 1, plan to replace it myself, does anyone have the diagram of the sensors location? I did a replacement awhile back for my lexus gs300 2001, not sure if the location of the 4runner and lexus are the same. Any help would be appreciated.
I not sure but I will call my buddy to find out and post what he says.
Got the info you need pm me your email I will send you the pdf on it.
The code your getting is caused by this OXYGEN (A/F) SENSOR HEATER CONTROL CIRCUIT LOW (BANK 1 SENSOR 1)
2004 4 runner V8 replacing oxygen sensor
I replaced my sensor 1 bank 1 oxygen sensor located on driver side pre-catalyst. Simply goe thru wheel hub panel by removing rubber shield which gives you easy access to sensor. Remove connector and test with Ohmmeter (should read about 16 ohms between terminals 1 and 2-the top 2 terminals with 2 black wires). If bad then remove sensor by using a 22mm wrench (may be hard to remove). Check new sensor for app. 16 ohms with Ohmmeter. Coat new sensor threads with anti seize lube and rethread by hand at first and tighten with wrench. Reattach connector. You are done.
Maybe a 2 hour job. BTW use a denso sensor to be safe. I bought one for $135 at KOI in Indiana.
You can erase codes in memory by removing EFI and EFSC (right next to each other) fuses for 60 seconds in engine fuse box or just erase with scanner.
Drive the car and be sure CEL doesnt return. Done!
AFRs in the front, O2 in the rear on most Toyota's these days... can't remember if Federal vehicles used 4 O2s or not; that always seems to be a weird grey area.
Hi guys, sorry about reviving an old thread, thought it would be better than starting a whole new one.
My 2003 Sport V8 came up with this code a couple months ago. I am going to tackle it the weekend and need to he the sensor ordered. Given what I've read, there are 2 different types of sensors.
With a P0031 code, which sensor am I looking at? Comments above say pre-catalytic, by the Amazon link above for the 02 sensor says it's a downstream sensor???
Any help would be appreciated!
"O2" sensor is the downstream sensor. You want the AFR "Air Fuel Ratio" sensor. That is the "upstream" sensor.
Thanks for the info man....I've ordered a Bosch sensor on Amazon, expect it in on Friday. Hope to knock this out on Saturday. Should be an easy replacement on a lift!
I am having issues with an a/f sensor. It was a p0031, I replaced the sensor and instantly got p0032, can't figure out what the deal is with it. Runs great otherwise.
Did you reset the codes. I just dealt with the p0031 and replaced it with this O2 sensor. Amazon Link
I reset the codes and it never came back. I got free loaner O2 sockets tools from Autozone and the whole job took 15 mins.
Yes I reset the codes. I have tried numerous times and every time the p0032 comes back instantly.
I used a sensor direct from Toyota as well. I have tried to figure out what actuates the heater circuit thinking maybe a relay was stuck or something causing the heater to stay on all the time.
Hey guys, so I'm getting O2 sensor codes P0141 and P0135 (heater circuit). They are both brand new Denso sensors, originally replaced because the other two were bad. Anyway, I had no issue from the new ones until I had my headers redone. Redone as in fixed a couple of small leaks and powder coated. After I installed them, I started getting the codes. I pulled them out and whiped them off, sprayed the connectors with electrical connector cleaning agent. Still getting the codes. Someone mentioned that I am suppose to have four sensors. I notice an additional spot for a third sensor on the y pipe but it has a plate bolted over the hole. Is there suppose to be another? Any advice? I've been dealing with this for three weeks now.
Any update vandy756? Did you fix this? I'm dealing with the same thing after an engine swap. Tired of seeing the light.
Forgot to quote previous post
seltzernator
