I have been reading a lot, but I am not of mechanical mind so a lot of what is being said is going over my head and I am just not sure what is needed...if you could advise me or confirm my assumption on this I would appreciate it.
I have 160k very temperate CA coastal living no towing, wheeling, or heavy loads.
As stated earlier, just a little confused on some things...
is there a way to check for this pink milk shake thing as it stands right now, I do not know of any problems, does it slowly leak and mix or is it one of those things where you are fine and normal one day and the next day it is spewing?
As I understand it, the external trans cooler B&M 70268 is the prefered cooler on this board, if I chose to go with the external cooler, do I just install the cooler and that is it? or do you need to do fluid flushes along with it?
Also being that I am at 160k, I realize some suggest swapping radiators but if the one I have is seemingly fine right now and I choose to put the trans cooler on, is there still a pink milkshake risk with this radiator once the external cooler is added?
I have friends that wrench a little bit on their own stuff and they could probably help me, but is this trans cooler and/or radiator swap something you have a shop do or can your average DIYer get it done?
I want to do something to ensure I prevent this from happening to my 4runner, I am thinking I would just like to do the trans cooler for now cost wise it is cheaper and seems to do the same thing and that way if i dont have to mess with the radiator it can stay...
$62 on amazon is not bad for preventative...
Amazon.com: B&M 70268 SuperCooler Automatic Transmission Cooler: Automotive
thanks...
thanks...
