Part number and source for fender flare part
Kyngfish
Hi all,
My black with grey trim 1998 limited has a missing piece of fender flare that goes right over the front bumper on the front wheels. Just wondering if I can buy it OEM in the correct color from somewhere at a reasonable price? All I can find is the entire flare, and I just need one part.
Any pointers are appreciated.
Best,
I think your looking for part # 5210235901 for the right side or 5210335901 left side. List price around $84. It might need to be painted to match because I'm not seeing an option to order by color.
^ Those are the correct p/n for July 1998 and earlier production date.
If the production date is after July 1998 then the p/n would be:
52102-35902 right side
52103-35902 left side
Posting here on an old thread, because I don't have enough post to start a thread. I have a 2000 SR5 and am looking for the bottom front fender flare section as well as the front tip for the running boards for both sides. I thik the previous owner was probably running tires that were too large and damaged them, then just disgarded them. Are there any OEM or accurate aftermarket replacement sources other than the dealership?
Pictures would help...
-Charlie
Not sure I have enough post for pictures.
Won't let me upload pics. OK I think it posted.
You have the "skinny black" flares, not the ones otherwise posted in this thread. Do you just need the one drivers side flare extension?
If you are going to remove the running boards, get these:
3rd Gen 4Runner Mud Flap End Caps – BH3D Printing
If you are keeping the running boards, you will have to find that part used. They are long out of production.
I might still have mine in the garage - I can't remember if I already sold them...
-Charlie
-Charlie
I need both sides - flare extensions and running board ends (front).
If I had to guess I would suspect the previous owner tried to run tires that were too large and ruined them, so they were removed.
Hi I have a 2022 trd 4runner. Part of the rear fender broke off. The plastic broke off from the bolts. I have the fender piece and its in good shape. Anyway I can put this back on even though the plastic is gone. Any advise would be appreciated. Thank you
You are in the 3rd gen section (1996-2002). You have a 5th gen. Here's the 5th gen section: https://www.toyota-4runner.org/5th-gen-t4rs/ and a 5th gen section specific google search: https://www.google.com/search?q=sit...BAPgBAvgBAeIDBBgBIEGIBgE&sclient=gws-wiz-serp Good luck!
