Passenger Fender Removal
felrivad
Hey everyone, new to the forum. I need to remove the front passenger fender to get to the antenna and remove it since the motor broke. Can anyone please tell me how to do this ? I dont know what screws to remove?
no no no dont pull the fender..
look under the fender and u will see a black plastic called your inner fender well.
holding that on are a few round head clips (some screws if its a limited) you will most likely break the clips trying to get them off. its a rectangle clip with 2 fingers that stick out on opposite sides.
i use a pair of needle nose plyers. wire cutters /dykes. and flat head screw driver. pull that inner fender and the motor is right there. its held in by 4 bolts and a clip for the power wire.
There's a step-by-step here that should help:
http://www.toyota-4runner.org/3rd-gen-t4rs/133346-1998-antenna-mast-install-dealer-wanted-over-$200-00-a.html
DanielShawSZ
