Passenger window not closing at first...
DigableKid
Hey all,
It's been pretty hot in Cali so I decided to keep all my windows rolled down about 2-3 inches to keep it fairly cool throughout the day. When I got in, started the engine and rolled up the window (using the automatic feature), the window fully closed and re-opened. I thought I accidentally pressed the close button so I, again using the auto feature, rolled the window up. To my surprise, it reached the top and started opening again. I'm taken back cause this is the first issue I've ever noticed since owning the the Runner. So I get out and walk around, opened the door and rolled the window down using the passenger controls... this time around, it stays closed.
Has anyone experienced this before? I'm trying to persuade myself to thinking that it was the heat causing the anomaly but this is an issue I want to nip in the bud before it worsens.
Thanks for your time in advance.
All the best,
Dig
P.S. I searched first.
Had the same thing happen with mine--I was due in for service and when the dealer checked it it had quit doing that. I didn't totally follow him but he pretty much said that they will do that sometimes but then "self adjust" which apparently they did. This was back in the spring and it hasn't happened again.
Thanks, Billmaks. That's a relief. BTW, did he tell you what activates itself adjust?
