performance "chips" for 5th gen
I'm not interested in more power, but more fuel efficiency. As we add racks, tires, lifts etc our trucks become pigs on the highway. Maybe there is a chip or programmer out there that has economy settings for highway driving and then maybe towing and off road settings that change shift points and throttle response rather than actually changing the hp performance of the engine. Anyone know of anything like that? My buddy just got one for his jeep which does just that from super chips. It also calibrated his speedometer for his 35's
I'm really not sure if there's going to be anything more efficient than Toyota's original programming. It's not as if the 4runner was tuned with performance in mind from the factory, so I'm pretty sure Toyota has already extracted every last drop of efficiency there is to extract. Loosing fuel efficiency just comes with the territory IMO.
My old 2001 VW Passat 1.8T had a performance chip installed. HP rose from about 150 to just under 200 but the torque increased more significantly...from 150 to 250. It was quite remarkable!!! It was from APR if I recall correctly.
Ah yes...here's the APR website...
APR VW Passat 1.8T - APR ECU Upgrade
d1ae5b2d7cb44619c002c4f0e467294c_zpse0df7cc0.jpg~original
The first thing most folks upgrade is the engine. They boost horsepower (somehow) and then end up blowing a clutch, transmission or rear end. The weak link goes first; because vehicle componets are made to work together, like 1engineer said.
Tuning is much simpler on forced induction engines.
You need forced induction to create more significantly more (15+ HP) power on naturally aspirated engines, period. Also, don't put your warranty at risk, it's not worth it for 5-10 HP that you actually won't be gaining at all.
4runner 5th GEN REPAIR MANUAL
Fallow this Link to my Drive on google, there are 73 Documents
https://drive.google.com/open?id=0B0ChhsF6x3jBYklRaG9vcjk3MHc
These Documents ware Download from
https://techinfo.toyota.com
The Technical Information System or TIS is your service support source for all Toyota produced vehicles marketed in North America. TIS includes all of the vital information you'll need to effectively service most 1990 and later Toyota products.
Select the Manuals tab above to view Owner's Manuals, Emergency Response Guides, and Dismantling Guides free of charge.
TIS is available in three different levels. The table below summarizes the features of each subscription level.
TIS Library
Standard
Professional
Diagnostic
Security
Professional
Service Bulletins
Repair Manuals
Wiring Diagrams
Technical Training
Other Technical Information
Diagnostics / Reprogramming
Techstream Scantool Software
ECU Calibrations
Identifix Direct-Hit
Security
(U.S. and Mexico VINs only)
Key Codes
Immobilizer / Smart Reset
TerryNap61
