Pic Request: LE 275/55/20 with 1.25" wheel spacer (adapter)
gonzanc
I just had the 275/55/20 Terra grapplers installed on my 2014 and while they add to the width of the tires a good bit, I was wondering if anyone has also added the 1.25" wheel spacers (adapters) to this tire combination and has a picture they are willing to share? I am thinking the wheels/tires will protrude beyond the wheel well with this tire combination and spacers, but wanted to see if anyone had done this
TIA
Did the installer have any problems installing that tire?
No issues with the General Grabber UHP in that size. Then again, General says that tire in 275/55/20 will fit a 7" wheel. As of now there are only 3 tires of that size to actually fit within the manufacturer recommendations...
***update w/ pics***
I decided to install the spacers today.
275/55/20 Nitto Terra Grapplers
Toytec leveling plate
Allpro 1.25" spacers
Pics....
More....
Your truck looks great! I have the exact same one and am looking at putting the same tires on. Do you have any rubbing with the Terra Grapplers? I'm installing the DS 2.5/1.5 levelling kit and possibly spacers.
How do you like the overall ride? Did it change much from stock?
Thanks.
275/60R20 Input
Looking for some input from those that installed 275/60R20 tires on stock LE wheels. How many of you successfully installed this tire with a Daystar level kit & 1.25" spacers? I understand at worst case, I'll need to do a BMC due to the spacers but I'm also wondering if anyone has run this exact set-up with spacers & only had to trim/mod fenders without doing a BMC? All the posts I've seen/read, no one is running this size of tire/lift with spacers, & if they are, it's not noted if they needed to do a BMC.
