Pic request: Method Standard / Double Standard
Highlex
I am looking to buy rims for my 2004 sport, I have a couple questions.
What rims fit the truck better, the 17x9 standard or the 17x8.5 double standard.
The standard original has a lower offset, so it should stick out more.
I am looking for a wider than stock stance.
Any input or pictures is appreciated. Thanks!
I have the Standard.
Cooper S/T Maxx 285/70/17
17x8.5
4.5 backspace
Front bumper trimming required. No body mount chop needed.
Thanks for the pictures ^
I want to get a 17x9 rim, not a 17x8.5
The method standard is available in a
17x9
Offset: -12mmBackspacing: 4.29"Bolt Pattern: 6-139
Weight: 30.2lbs.
and Method Double Standard is only 17x8.5
17x8.5
Offset: 0mmBackspacing: 4.72"Bolt Pattern: 6-139
Weight: 27.8lbs.
I want to get the 17x9 Method Standard, but im wondering how that would fit, and if anyone has pictures?
The 17x9 and -12 offset will give you a wider stance if that's what you're after, be prepared to trim the inner bottom portion of your front bumper and move fender liners forward, possibly even do the body mount chop but not sure.
