Pic Request: Sport Edition nerf bars/running boards on non-sport t4r
84ability
As the title says, looking for those that have swapped their square running boards for sport edition round tubes. I'm trying to get a feel for how it will look with the factory black, square, non-sport roof rack up top. Thanks in advance.
2.5 year ish ago!
Technically not what you were looking for since I am a sport. But I figured you were looking at the rack. So hopefully that helps
Looks great. Did you mod them or did they bolt up that close to the bottom of your doors? The gap looks tighter than I thought it would, I like it.
Mounting them to your 4runner will look like any 2006+ sport out there. Mine being a 2004 has different lower door panels than yours. They will bolt the same to any 4th gen t4r.
I didn't leave them on long. They stuck out too far for me and I constantly hit my pants or legs on them.
gotcha, thanks for clarifying...never knew there was a difference.
They'll look fine and that's what I did.
The tubes and the roof are so far apart, almost nobody will ever notice.
IMHO, the tubes look much much better than the surf-board.
My only issue is the lack of running board lightning. Gives alot of definition to my limited 2007
Sent from my XT1575 using Tapatalk
tons of ways to fix that. You can put led's anywhere. Lots of ideas on the ole website here. I have them on the bottom of door panel when door opens lights up everything on ground. I had them under the body as well. but like the door better.
Have seen someone put them into the tubes as well.
Not the best pic.
08 SR5 with sport tube steps. I repainted them with rustoleum primer then rustoleum bedliner (both rattle can).
Here is a side view, you can see they fit tighter to the body than the running boards do. They use the same attachment points.
Have not thought about mounting to lower door. Now you have me thinking. Have any information or pictures of your attachment to the bottom of doors and wiring?
I can get a few pics. no problem
I pulled door panel and wired into the light in door panel.
Front door has 2 strips, rear doors have one.
Excellent! It's funny that you're showing me a strip of LEDs, because just recently I created a post I find LED products. There are so many of them comma where did you get yours?
I bet they're bright too
