Pics of 275/70 tires with 3" Lift?
Raoul_Duke
I'm currently running BFG KO2s, size 275/70/17 with Bilsteins set at 1.75" up front and a 1" cornfed spacer in the rear, but I'm thinking of installing OME springs all the way around for what I understand will be about 2.5-3.0" of lift. Before I pull the trigger, I'd like to see some pics of trucks with a similar configuration to see how this size tire looks with this much lift. Post up if you have 'em, please. Thanks.
Here's my 4Runner running Dobinsons 3"/2" lift on 275 BFG K02's
I think this is exactly what I'm going to do. I was torn between 16'' and 17'' wheels, but am leaning towards 17s.
TRD Pro with Cornfed 1.5/1” spacer lift for a total of 2.5”/1” with 275’s.
Can you post pics of your setup? I'm currently running the same height with 6112s but w/ 265s. Thinking of upping to 275s but I don't want a stuffed wheel well
Here you go. Personally, I don’t think the wheel wells look stuffed at all with this configuration, though I thought it did before I got the lift.
seltzernator
