greasefingers
kdx2000 said:Man, just when you thought you have heard it all.....I say he is full of crap! I have never heard anything like that. The red colored anti freeze is propolene based and the green anti freeze is glycol based. You can't mix the two!
The Toyota Long Life Factory Red Antifreeze Fluid is: Ethylene Glycol, diethylene glycol, and then the third listed component is water. Exactly the same is printed on Prestone. However Toyota states that it contains no silicates (that may harm water pump seals) and no borates (that may cause aluminum corrosion/pitting) Prestone also states that the additives in it protect aluminum corrosion.
I believe the two are very very similar or maybe even the same exact product.
