Plastic bushing for rear window tracks
eanema
Hi All,
Last week my rear power window fell when I hit a bad patch of gravel. One side of the window fell into the door leaving me with a wonky rear window. When I got home I opened up the back door and found that there was a little plastic bushing in the window track, and I could just pop the window lever arm back into the bushing.
Well today I drove over a set of railway tracks and the rear window fell again. This time when I opened up the rear door I found the plastic bushing had split in half.
The window mechanism seems to be in good (decent?) working order although the tracks are fairly rusted. I was going to remove the back window, then the tracks, clean them up with a wire brush and paint then grease them. The problem is I need to replace this broken bushing (and the other one too). I have searched around a bunch looking for part numbers or solutions but I haven found anything.
Does anyone have part numbers for these? Or any solution to replace them?
Much thanks
Damn, I was afraid you were going to say that. I guess Ill just have to make it work... Ill let you what I come up with
Passenger side or drivers side?
I already there away my old driver side, but I am about to change out my passenger side. I can send the whole assembly to you for shipping. It actually still works, I just changed the driver side lit cause it didn't work, and the replacement worked really well. So I decided to do both.
It is the plastic bushing on the rear hatch/lift gate on the passenger side but I figured that I would replace both while I was in there if I could find a reasonable solution. By the sounds of it you are referring to the rear passenger door, yes? And reading back I see why that may have though that, haha oops, my bad!
I am actually referring to the back door/tail gate.
AndiGarage
