Well, I may have been a little premature with my praises of the
emblem front facing camera as I have now been through two of them and I am now wondering if the way I am wiring them is causing the issue???
I connected the positive and negative lead of the camera to one of my SPOD terminals. When I connected each camera the very first time, it showed the display on my NAV as expected. Then when I did the test again on another day, just before permanently routing the wires, the cameras failed to show a video. The first camera I returned and reordered the second one so I thought it was the fault of the camera. Now the second camera is doing the same thing so it must be my specific application, right? This second time, I also noticed the main wire (which as the video and positive and negative power wire wrapped) was really hot. I did notice that I plugged the camera power wires into a 30A fused circuit, but that shouldn't matter right? The camera will draw what ever amps it needs.
NoOneBetter is using this same camera getting power from a tap to the stock fuse box and I don't think he has had an issue. I find it hard to believe I got two bad cameras in a row. Is this a problem with my SPOD perhaps? The camera is the only aux device I have tested it with. I tested the volts at the SPOD terminal and it is 12.X with out the motor running and 13.x with the motor running. Can any of you please suggest how to troubleshoot?
Adding mentions to bring in [MENTION=83083]rigtec[/MENTION] , [MENTION=129513]bjohnston115[/MENTION] , [MENTION=56922]NoOneBetter[/MENTION] for their suggestions.
