Possible MC ABS unit failure
benztech82
Member
Hey all,
I got a weird brake issue. When I press the brake pedal it feels fine for a second and then it's slowly going all the way to the floor.
No codes, tried bleeding brakes with scan tool as usual, rear with scan tool and front conventional with buddy assist. My truck is 08-2004 which is a part number change for ABS unit. I suspect that I have to replace the whole unit but not too sure and don't know if newer unit will fit from 2006+ since mine could be with older unit from 2003 up to 2005. Did anyone have this exact issue or knows if older 4th gen can have 2008 ABS assembly?
Thank you!
Hey all,
Thank you!
Did you thoroughly inspect your rotors, pulled each one off and looked at both sides? I was sure my M/C was failing earlier this year but on advice from Car Care Nut, I did a thorough inspection and found a seized caliper and backside of one front rotor wiped out. Replaced with new and all is good!
My brakes fully serviced, I guess unfortunately in this case. All calipers move, pins not rusted and pads and rotors evenly worn, passing safety.
