Post your LIFTED pix here!
Jeep Safari Easter Weekend 2015
Ready lift 3/2 alignment?
Hey do these alignment specs look in line with what you are getting out of a 3/2 ready lift?
finally worthy of posting in this thread! Here's the details:
- 2014 trail w/ kdss
- toytec adjustable "diy" coilovers set to about 2.5" in the front
- bilstein 5100s in the rear with 1.5" spacer
- 285/70/17 falken rocky mountain ats tires
- level 8 mk6 in 17x8", -10mm offset
Finally after 1.5 yrs, got the lift and tire. Billstein 5100s, 1.75" in front, 1" cornfed spacer in rear. Had to keep it fairly mild, this is my daily driver and family hauler.
Tires are Cooper AT3 265/70/17
If I have to get serious at the trail, I have this. 2014 Rubicon X.
This is my 2010 Tacoma access cab. Also had a 2007 Tacoma double cab, but could find a pic.
This is what started my love with Toyotas, my 1985 4Runner.
Sitting on Bilstein's. Debating if I should go 3/2...
How are you liking the 6112s/5160s? Do much wheeling in them yet? Which circlip setting do you have the front at?
I am currently debating whether I should save (for a while) for full KING Suspension or if I should go the Bilstein 6112/5160 route...any information on your experience with them will be very appreciated.
Thank you!
Thank you!
It's currently on the 4th clip. ~2.5" Haven't wheel that much or push to the limit. May not be the best person to ask but I have push the speed on some rolling trails and it has performed admirably. Soaks up the bumps pretty well at higher speeds. If you have the funds and push to the limit, might as well start with the Kings and be done with it.
just got a 2.5" lift F/1" R and I'm wanting to fit 285/75 trail grapplers, would this still be practical for an occasional wheeling? would y'all recommend it?
Nice tire choice... I think we are the only two 4runners with the Toyo OC RT's on this forum. Only time will tell if we made a good choice.
I'm sure I'll get flamed for this but here it goes anyways... Do you think the 295 RT's would fit? They're actually a few dollars cheaper than the 285's. I'm not afraid of cutting into the body mount -- I made 38's fit on my JK with only a 3" lift.
johnnya
