Post your wheel offset and help me understand
Thirty4
Post up your pics of your wheel offset and help me understand what I need to do to get a wider stance. I am interested in wheel offset for a 2021 4Runner TRD PRO. I am not sure how much offset is on the stock wheel, but I want to replace those wheels with a wheel that allows me to get the tire in-line or just a touch outside the fender. I really like the wider stance, but I do not know what I would need to purchase to get there. Please note that I do not want to use wheel spacers. And I do really like the rims on the PRO, but this time around I really want the offset. I would also likely put a 285/70/17 or a 295/70/17 tire on the wheels. That would also change if I went to an 18 inch wheel or down to a 16 inch wheel. So, if you haven’t guessed, I need a lot of help with this to understand what it takes to widen that stance!
EDIT: For clarification, I am willing to mod, just wanted to try and avoid the BMC. But, I have had some great advice here and it does not look possible unless I go all the way on the mods. Thanks for the help everyone!
I’ve got OEM wheels and can’t really help you with the offset questions. What I can tell you is that 16” wheels won’t fit on your 4Runner as they don’t clear the brakes.
Are you willing to do UCA, bumper trimming and possible BMC?
My general observation is that anything 8.5 and -10 offset a la SCS or your popular Japanese makes (Volk, Enkei, Works etc) is going to be pretty flush on 33’s.
Moving up to 9 inch wide and -38 with SCS or -24 with Summit off roads, you’ll have that poke but will definitely need the modding.
Just for comparison, your stock wheel is at 7 inch with a single digit offset. Any of the above will be a noticeably wider stance.
Dirtylife Roadkills
17x8.5 -6 offset
285’s
Sent from my iPhone using Tapatalk Pro
Would like to avoid the BMC, but I am fine with UCA’s. This information is great and really helps. I will likely have a question after I can look up some of the offsets and wheels that you mentioned. This part is just virgin territory for me, so I am taking all of the help I can get! I really appreciate the information.
Stocks are +15
pics won't help you understand it. do some basic googling and look at drawings that show how offset works. the stock wheels are +15. the oversimplified version is that any rims the same width that are from +14 down to negative numbers offset will have a wider stance. anything the same width with +16 or higher offset will have a narrower stance. wider rims will have a wider stance unless they are significantly more positive offset.
if you want a wide stance, you want the SCS-38 wheels with a BMC, or other wheels with spacers and a BMC. I spent months looking through instagram and every single wide stance 4runner either had spacers or the -38 offset wheels. that's all there is to it. you have to run 17" or larger diameter wheels. if you run anything larger than stock tires with wider offset wheels, you have to do the BMC and fender liner. you do not necessarily have to do UCA.
My recommendation would be to get a small 2” front 1.5” rear spacer lift for your Fox shocks, i.e.; Wescott, ToyTec, Burtman, etc. Add some 285/70-17’s and call it good. No BMC required and the fender mod is already done on the Pro. The wheel width, offset and look of the Pro wheels with 285’s will look great. You can even keep your mud flaps. A 285/70-17 will also fit in your spare tire location. Start there IMO.
Wow…..I love your stance! That’s what I am talking about! But, I am guessing you may have a BMC mod correct? I will check out the site that you mentioned. Very helpful!
to fit these tires and this much offset, you need BMC, UCA's, fender liner trim, possibly pinch weld mod, and cutting the plastics in front of the front wheels.
That’s a bummer….thanks for the information. I figured that may be the case to perform all of those mods. I may just stick to the OEM wheels and just do a 285/70/17. Or change the wheels for a wheel with a small offset and still do the 285/70/17 (that is if it’s a 17” wheel of course). I really like the wider stance, but I would rather not tackle a BMC to do it. Damn….I was really excited about widening that stance without all of the mods. LOL. I feel like a little kid who dropped his ice cream before the first lick!
The standard wheels on a TRD Off-Road 4Runner are +15mm offset. The OP mentioned having a TRD Pro, which should have “sema”wheels at a +4 offset.
Thanks for the clarification. It is a TRD PRO wheel for sure. I really appreciate all of the help. In this case, if I bought an aftermarket wheel with a zero offset, just so that I am understanding this, that would move the wheel out…..by just a little bit of course correct? So, an aftermarket wheel with a negative offset, like -10, could move the wheel out even more correct? Just making sure I am grasping this.
That is correct; the lower the number, the further it will push out away from the hub.
With that said, you have to take an aftermarket wheel’s width into consideration as well. Almost all aftermarket wheels you typically see on a 4runner will be wider than the trd pro’s 7 inches.
seltzernator
