Power locks, windows, rear hatch working intermittently
Rob_E
Hi All,
My 2012 suddenly has problems with the locks, windows and rear hatch. Earlier today everything worked. Now, the rear hatch won't open. Thinking maybe it was locked I tried the driver unlock button. Nothing.
Key fob and passenger switches work. On the driver door, only the driver window works. All other window switches work when using they're respective controls. Maybe the switch panel on the driver door is bad, but it's an odd coincidence that the rear hatch button also doesn't work and both happened at the same time. Everything worked a half hour ago. Any ideas?
Hi All,
Check the wires in the driver side door hinge.
Hi All,
Did you find a solution? I’m having the same issue on my 5th Gen
Do you have aftermarket LEDs?
I can speak on the locks not working. I had a 2012 Tundra(Platinum) where the door lock actuator was working intermittently. After spending close to 800.00 at the dealership and only working for a couple of months, it came down to the aftermarket LEDs that were on the truck before I bought it. I ended up changing them and never had another issue with them.
johnnya
