Long story short, I had one of my drive belts shred due to age (I know, my fault). I ended up getting the truck to a local garage and went ahead and replaced all 3 of the drive belts. I should add that my truck's a 1997 SR5 with 262,000 miles. I change the oil and tires and have never had a single problem with until now. :cry2:
Everything was fine for the first week but I gradually noticed the steering was a little off. The next morning while going to work I immediately heard the power steering unit whining so I popped the hood, checked the reservoir, and it was bone dry.
My first thought was that they had to move the power steering unit when putting the belts on, pulled a hose off, etc. and lost fluid. So I went to the local auto store and picked up some ATF and filled it. Eventually the same symptom returned where steering started getting odd and one morning the power steering pump starts whining like crazy. Again, the reservoir was bone dry. There's obviously a leak somewhere.
I took the truck back to the garage that changed the belts and they assured me that they didn't have to pull the power steering lines, etc. but they took it in to look at it, just for due diligence. I later got a call from the mechanic and he said it's leaking from the power steering pump front shaft and that it appeared like a segment of wire from the old belt got twisted around the shaft and pulled it into the seal, which caused the seal around the shaft to fail.
Sorry about such a long post guys. My question is... How likely do you think this is to happen? And has anyone changed this seal before? I have a document that states I can just pull the pump, pry the seal out, and punch a new one in. Sounds a bit too easy to me but I'm no expert. I'll try and attach it here in case anyone was curious to look it over.
remo.pdf = how to remove the pump
repl.pdf = how to replace the shaft seal
Thanks for any feedback. It's much appreciated!
Mike
Mike
