pp springs/285's?
deadrift1
i know most guys can get 285/75/16's on a 99 4runner with the ome set up, but will the rubbing be severe when off roading with the pp springs front and back? they say there a 1" lift but is more like two". I appreciate any info.
dude, i rub with a 2.5" lift and 285s, a 1" lift is not going to be enough to clear those tires. i need to put a body lift on in order to not rub, but my COG being low is more important than a little rubbing...
put a 1.5-2" bl in just to be sure. you can prob fit them for street use, i wouldnt wheel like that though.
I have a 2.5 ome in back and my coilovers in front cranked up to 3" and i just added a 1" body lift and it still rubs when i go offroading.anyway just fyi
you'll rub with my setup of 5 inchs of lift. 3 sus and 2 bodylift at full compression with swaybars disconnected. 1 inch pp springs and 2 inch bl will barely do it for street use.
matisgugle
