Pro Comp 7189
sporty87
Pro Comp 7189 Wheels.
Thinking about Pro Comp 7189 Cast Black wheels 17 x 8" for my 10 Magnetic Grey SR5. I would like to put on 275/70/17 tires and would like to know if these would be a good fit not to get any rubbing with the Pro Comp wheel specs. being 0 Offset and 4.5 backspacing. I am not sure if they are Hub centic. I have Bilsteins in the front set at 1.75" and 1" lift being installed in the rear.
Also does anyone know if the Pro Comp 7189 Cast Black Wheels are flat black, or satin because I can't find a good explination of this.
What are the offset and backspacing on the OEM SR5 rims?
If I don't get these wheels what specs of offset and backspacing should I be looking for keeping in mind I will only be moving up to a 8" rim and a 275/70/17 tire and just looking for a more wider beefier look over stock?
:thanks:
You might get some rubbing running those tires on those rims. To fix it just move the Front inner liner forward and you might need to remove the front mud flap.
You have a small lift though, so the mud flap should be OK, just move the liner forward. Check this out http://www.toyota-4runner.org/537429-post145.html
The finish is the same as on my 7089's, Cast Black, it looks like a flat black.
They dont make the 7189's anymore. Matter of fact when I had to replace one of mine I got 4wp's last one.
