Problems in the rear
wahoossi
I have 2003 V8 SR5. My rear winshield wiper, washer and remote window control have all stopped working. I have checked the fuses and as far as I could see none of them appeared to be blown . As far as I can recall the dash rear window control works ( not my daily driver). Frankly it is not a huge deal if it they don't work , but it would be nice if there was a simple answer. Thanks .
Did you have your battery disconnected prior to this happening, or did you have any fuses or connectors unplugged? This happened to me once after having a connector unplugged to the internal fuse panel to work on something else. When I reconnected it I had lost all electrical functions in the back door, except inserting the key in the back door lock would still lock/unlock all the other doors. I forget exactly what I did to fix it, but I think I played around with the door lock/unlock switch in the drivers door and for some reason that fixed it.
You probably already tried this but, anytime I have issues with rear wiper problems I roll down the rear window all the way and then all the way back up. It resets a computer for the wiper or something like that. Usually fixes my issue.
I did not know this. Thanks for the tip.
You guys are geniuses! Or is it geniusii? Worked perfectly. Think you could give me some stock tips so I could become independently wealthy and be able to quit my job and screw around with my boat and truck all day and not have to waste my precious tinkering time earning a living?
charlesz
