Q's New Camper
These are portable generators that come in a number of sizes. Might be good for home use, but not as good as a hard wired unit with backup. Anyway, onto the products...
3.8KW: Honda EB3800XA
Maximum Watts: 3800
Maximum Continuous Watts: 3300
Maximum Amps (120V/240V): 31.6/15.8
Max Continuous Amps (120V/240V): 27.5/13.7
Engine Model: GX240
Fuel Tank Capacity: 6.6 gals.
Run-Time Full Load: 10.4 hrs.
Dry Weight: 185 lbs.
Noise Level at Rated Load, dB: 71
5KW: Honda EB5000XK2A
Maximum Watts: 5000
Maximum Continuous Watts: 4500
Maximum Amps (120V/240V): 41.7/20.8
Max Continuous Amps (120V/240V): 37.5/18.8
Engine Model: GX340
Run-Time Full Load: 8.3 hrs.
Dry Weight: 214 lbs.
Noise Level at Rated Load, dB: 72
6.5KW: Honda EB6500XA
Maximum Watts: 6500
Maximum Continuous Watts: 5500
Maximum Amps (120V/240V): 54.1/27.1
Max Continuous Amps (120V/240V): 45.8/22.9
Engine Model: GX390
Run-Time Full Load: 5.3 hrs.
Dry Weight: 220 lbs.
Noise Level at Rated Load, dB: 75
EDIT: MultiQuip & Wacker also make a 2.5KW if you want something smaller, but if you go with one of those, I'd recommend the MultiQuip because it has the Honda engine
Thanks everyone!!
@ Dusty Driftwood, good idea on the used i'll let you know. Also thanks for the info on he different models :thumb3:
@MikeG, Thanks for the links and the tips! Very much appreciated! I'm confused with this generator v inverter. I know how both work but whats the advantage of the inverter over a standard gen? Its late and i'm tired so maybe its just me not grasping it :confused:
I am no technical expert on this stuff, but an inverter type generator provides a cleaner power source, so you can safely run electronics with no fear of power surges or spikes. They are really quiet, which is really important for a generator used with a camper .
I have the Yamaha 2000 and it is really quiet and efficient.
Thanks! I was just researching them and thats what I read. With a standard gen the voltages can vary wildly when items connected ti it are turned on or off. certainly don't want surges/spikes melting my laptop, iPad, phone etc.
Thanks for the info!
@ Brockevery,
Are you running lift coils in the rear or still spacers? If coils where did you cut the bump stops at? do the mate up with the bags or is there a space between? Also can the valve stem be put up top so there is less of a chance of stretching or breaking the air lines?? Got any pics of your bags installed?
I have the ToyTec Superflex rear coils with Airlifts in them. I ran the lines through the frame rails so they are up out of the way then drilled holes on the top of the bumper behind the hatch for the valve stems. My bump stops are chopped down to 2 sections. I will see if I have some pics, I am sure I do.
Maximum Watts: 3800
Engine Model: GX240
Maximum Watts: 5000
Engine Model: GX340
Maximum Watts: 6500
Engine Model: GX390
All three of those are too big, and too loud.
You will be sick of hearing it after a few minutes.
Two ways to go, take this from the man that has camped off the grid for over 45 nights this year.
The cheap way is the generator below. I have had one of these on one of our horse trailers and a toyhauler for years (well over one thousand hours on each one). I carry one of these for when I need the extra power for AC and I do not mind noise and burning some extra fuel. Get if from CampingWorld with the extended warranty if you can, they will replace it for anything. Also, get the wheel kit. Your back will thank you.
Champion 4000 Watt Portable Generator-49-State Model - Champion Generators 46515 - Portable Generators - Camping World
To get the same power, but clean, you are going to spend some money. The Honda inverter units are great, but you will quickly be up around 2k. I never could justify this, so I ended up with another Champion for my quiet inverter. This one will be found cheaper than Camping World (I got them for under 1k for both and the parallel kit at Sams Club), but here is a link. I have spent most of my nights using these units (I have two I swap between and I have a parallel kit that will allow me to run the AC at sea level).
Champion 2000 Watt Inverter Generator - Champion Fulfillment 7353LI - Portable Generators - Camping World
Remember, the DB scale is not linear. The Champion standard genny is loud, and its only 68db. Those contractor units listed above will piss you off, as well as people for miles down the trail. Do yourself and all of us escaping the noise of the city a favor, and do not take them out there. My inverters are 53db and you can have a conversation over them. The standard genny at 75ft is still louder than the inverter at 5ft.
Here are a couple other things that I swear by.
BAL Light Trailer Tire Leveler - BAL 28050 - Chocks & Levelers - Camping World
This leveler will allow you to side to side level in a few minutes, and make the trailer much more stable.
Portable Surge Guards With LCD Display - Product - Camping World
These will keep a ****ty campground pedestal from frying your converter and other electronics. Pricey, but much cheaper than fixing broken stuff. I have had it kick into protection at 5-6 sites in the past year and half I have owned it, and it found one improperly wired pedestal.
The first one you posted is only a few dB quieter than the 3.8kW Honda. In my opinion, probably not that noticeable. The 2nd one however is much quieter at only 53 dB. The second one looks pretty sweet - compact, quiet & efficient!
Trust me, the difference is enormous. And the ones you listed are probably rated at a longer distance as most contractor generators are (25ft for camping style, most contractor gensets are rated at 50ft) The DB rating not being a linear means that only a few DB is the difference between being tolerable and giving you a massive headache. I have contractor generators for backup power, the difference is quite clear. Think having your truck with or without an exhaust.
Congrats on the camper.
We have a 20' Jayco trailer that we absolutely love. Limited tows it like a boss
I'm sure you would know better than I would. My only experience with these is on job sites. In my experience, you can barely hear the generator. Then again there is so much other equipment moving around on site that it is hard to hear anything.
In a quiet campsite, you're probably right and this thing would be obnoxiously loud. Either way, if someone is interested in the ones we carry and I can help, let me know.
Thanks :) I looked at a lot of hard wall campers also but most run a tad bit heavy especially in the mountainous areas I tend camp. What's the weight on your Jayco? Hope it's not as large as the picture :wink2:
That's awesome! I love those A-frame campers. I'm not sure how much you'll be using the camper and generator. But, when you're ready to buy the generator, you should look into buying a used unit.
I work for United Rentals and we carry those silent Honda generators you referenced and we're always selling them used for cheap. Let me know when you're ready to buy one and I'll try and track down a good one for you. I won't make anything off it, other than gladly helping a fellow T4R member. :bigok:
Dusty, Let me know what you have now, I would like to get a generator sooner rather than later. Thanks!
Sure, what size do you think you're looking for? Let me know what you want and I'll track one down for you.
I'm thinking the Honda EU2000i1A1 2k inverter generator would be a good choice then if needed I can add the companion in the future. What do you think?
ghengiskhan
