Question about bleeding 2001 brakes
Crashnrondo
I'm getting all the parts together for a Tundra upgrade including speed bleeders and I have read 3-4 different write ups on the upgrade but... When I bleed the brakes on this model do I have to put the cap back on the master cylinder after every time I top it off or can I leave the cap off and just fill as needed? Also the key needs to be turned to "on" not running but "on" correct? I have bled motorcycles a bunch of times just never a car or truck.
Thanks,
Ron
After doing my TBU I just left the cap off and filled as needed (I lost a tiny tiny amount of fluid after pinching the lines). The speed bleeders will make a quick job out of bleeding the brakes.
As for the key, the on position is fine to initially bleed them. Once I had them bleed with the truck off, I did it again with it on. Probably didn't need to but with speed bleeders it was super easy. Whole process took me about 5 minutes.
Thanks for the reply, but I think the brake booster is different starting in 2000 or 2001, it uses a small pump for pressure. Or maybe I'm goofed up?:confused:
You're right. '99's bleed just fine with the key off, but not the newer ones. (I'm also not sure of the year.)
044runner4
