Question about tires
Cronoscr
sorry if this is old but did not find much (perhaps they do not look good)...
Now I have to change my tires and I was thinking about 33, which would have to do to take them?, My motor (ikzt) will move the right? the idea is to buy dual purpose (Roll lot in town) or better scrap my idea and buy the typical 31?
My car is stock, thanks
But they have told me that all stock 33/11 does not work, is this fake? is a big investment and I do not want to have problems, thanks
32s are what most fit with stock truck. To be safe 265/75/16(32"). 33s work better with 3" lift or more.
thanks! but what happens if use 33s?can i use them and then lift the car or not at all better? (In my country 32s almost not obtained)
Yes. A 3" lift will/should accommodate a set of 285/70r16/17 or 33inch tires. Your question is can you buy a set of 33" tires and not lift it, and than lift it later? Not sure if I understand exactly what you're asking.
I had to do some cutting of my front bumper lower valence when I installed my 33's. That was with a 3" lift. I have now added a 1.5" body lift on top and when fully flexed offroad I still rub a bit but not an issue really. So I would say NO you cant because you will have a lot of issues rubbing.
That was exactly my question, stock can not be mounted 33s, these changes are so expensive?
