Question on 20' rims...
daytonaSURF
Well it looks like im finally getting closer to my 20' Enkei Deep 6's for my 4runner. But I have a few questions, the rims are (pretty sure) 9.5 inches wide. Everywhere it says they will fit, but what will I need to do? Nothing major right? Is there anything else I should know about getting 20' nch rims before I do? Thanks A LOT in advance!! :D
First off...
Does it Rub?
Do you have the right size for tires?
Are you willing to accept a DECREASE in ride quality?
You know, changing wheels is fun.. but it severely alters the safety and dynamics of any vehicle.
and secondly... you need to post pictures up here when you have them on! :D
personally I think smaller rims and larger tires fit the 4runner better than large rims and smaller tires but to each is own i guess. 20's are going to be a pretty rough ride too won't they?
So I shouldnt have any problem with rubbing or anything? Is there anything else I should know before I take the plunge and get them? Thanks!
No you won't have a problem with rubbing. I have falkens 295's
Ride quality did decrease slightly. And you'll need road force balancing, but it looks bad a$$.
the 9.5 depth gives it a much wider stance that completely fills the whell well height and width wise.
As for the tire pressure monitoring system, the sensors will not fit, because of the metal exterior washers. The air pressure will leak.
Tundra's have the new sensors, with rubber seals that fit these rims.
need more clarification..
A buddy of mine have the Enkei deep six that is 15mm offset with 108mm bore on his 96 4Runner. Will the same wheel with those same specs fit on a 05 4Runner? Thanks!
