Quick question tundra fabtech dirt logic question
Diggo
I have been searching all over this site to find out if tundra 2wd front coil struts will fit 3rd gen 4x4 4Runner. It's time sensitive and I am looking for a little help if they will fit? If I may need to get a new top plate because they man not line up with the 4Runner bolt pattern! Thx in advance, diggo!!
Might help if you provide more information. Like, What year tundra?
The bolt patterns wont line up and chances are they will be valved totally wrong for the 4runner. Having them rebuilt and having the spring potentially swapped so that it would be the correct spring rate (I think the tundra ones are 700lb/in which would be very stiff in the 4runner) will be expensive and probably not worth your time.
Some of the top plates will have holes for both bolt patterns, but it not a sure thing so you might have to replace it or have it drilled+tapped.
Edit: This is for FIRST GEN TUNDRA, Second gen will not fit at all.
Laredotx
