Raptor Lights 2020 4Runner
JsinLegacy
Has anyone with a 2020 installed these yet? Looking at ordering some but seeing people saying the fuse boxes are set up different and they are unsure of where to plug them into.
Any info would be appreciated. Thanks.
I have both the raptor lights and the TRD Pro grill from cartrimhome.
Raptor lights - will fit the 2020 with no modifications. The cabin fuse box is located in the same spot as the other 5th gens, its just the arrangement of fuses is different. I have mine tapped into ACC fuse and it works great. Also have a fuse tap on IGN for my s-tech switch.
TRD pro will definitely require some modification wasn't that big of a deal. I'll eventually post pictures and instructions. I've been too busy with post it up.
Found two courses of action apparently for these. 1 is to use the TAIL fuse spot on the inside of the cabin, although responses for that seem mixed. The other is to use the INJ location under the hood. But you won't be able to fully close the lid because of the add a fuse device.
2020 TRDP.. just bought some nice lights on amazon and followed one of the millions of DIY videos on youtube
false ... was able to follow a video on youtube, shows you if u remove a bolt, youll be able to install the wire to the fuse re-secure that bolt and then close the lid
Can you link me to the video please. Would be greatly appreciated.
I was just going by what I've seen a few people saying on some install videos for them. The videos are not of a 2020 model but people with them have been talking in the comments.
I did the same thing. Ran it to the under hood IJN. Used the method of running the wire up through the bottom side by loosing the bolt. Forget the exact video but it’s under runnin for tacos YouTube site. Search for raptor or grille lights on his channel.
There is also a guy on you tube Chris has a 2020 white pro 4runner ran the lights. But he did not do what running for tacos did.i believe he said he has to run the wire differently. I’m going to do on the video from running for tacos did with removing the bolt at the fuse box.
I got the lights in and followed the video you posted. I'm just curious how you got the lid to close completely with the add a fuse plugged into the INJ location.
It sits on the far left, if you are standing on the side of the vehicle looking at the box, and already sits up higher. When I plugged the it into that location the lid will only shut on the main clip and the top left one. The clip closes to the fuse and vehicle will not fully clamp down. Essentially the clip sits on top of this location.
Thanks for any help you can provide.
I have mine plugged into the fuse box in the cabin interior, I ran the line through the fire wall.
i can send you a picture when i get home
My lights from cartrimhome lasted less than a year and customer service has been unresponsive. Would not recommend them.
2020 TRD Pro here.
I just ran them to the INJ fuse. The fact that the fuse box doesn't shut all the way in that corner doesn't really bother me at all.
here you go
AndiGarage
