RCI Metalworks **FEELER** KDSS A-arm skids
st8rocks
I was speaking with Josh at RCI about a-arm skids for KDSS trucks. He said they are in the works but if we can generate some interest the prototype will get moved along faster. This is simply a feeler thread, NO COMMITMENT!
Here is a link to their current A-arm skids:
03-09 Toyota 4-Runner Transfer Case Skid Plate
The non-KDSS skids start at $115 so expect maybe a bit more for KDSS. I stressed to Josh that I am looking for a skid that extends forward enough to protect where the KDSS piston bolts to the A-arm.
Sign-up! 10 would be ideal to get the wheels turning.
1.st8rocks - Kevin
2.Mooney
3.Sunriser
4.kpd1999
5.Factoryride
6.Javelin
7.
8.
9.
10.
The non-KDSS skids are $115 so expect maybe a bit more for KDSS. I stressed to Josh that I am looking for a skid that extends forward enough to protect where the KDSS piston bolts to the A-arm.
1.st8rocks - Kevin
2.Mooney
3.
4.
5.
6.
7.
8.
9.
10.
Done!
1.st8rocks - Kevin
2.Mooney
3.Sunriser
4.kpd1999
5.Factoryride
6.
7.
8.
9.
10.
I'd definitely be interested in them.
I just ordered a set. Shouldnt be too much work to just alter it a bit to work with the kdss. Assuming you have access to a welder.
I often wondered why someone hasn't made these already. Excuse me if my question seems funny but I read this and was confused.
I am thinking you meant where the sway bar bolts to the a-arm? As the piston comes down and clamps to the sway bar near the bottom of the radiator and the sway bar bolts to the a-arm.
In that case would the skid be covering those bolts?
I imagine one could buy a regular set and use a plasma cutter and cut out the section where the bolts for the sway bar connect. But it would be much more protected with the skid covering that part too.
