Jew_97YOTA
I first want to say that I am thankful for all of the awesome information I have gotten from this site, thanks to the amazing community.
I have a 97 4runner and am in the middle of changing the rear wheel bearings. I have done this twice now on the other side of the car since the first time it was done the oil seal wasn't seated right. So Im familiar with the process. My problem is that after i took the axle with all the new parts to the machine shop they called me and said the outer bearing seal was not the right part.
So i went to see if oreilys gave me the wrong part. after some searching I found out the seal that came off of my axle was from an 02 4runner. This made me recheck the parts numbers on all the other parts and make sure there werent any major differences between my 97 and an 02 Runner.
I found that everything is the same but the bearings and the Bearing housing(knuckle). The difference in the bearings is the 02 inner bearing race has an extra flange or spacer sticking past the face of the bearing.
The bearing that was on the axle when i pulled it out was for a 97 4runner. and the shop said that there was a lot of play in the bearing housing. My theory is the mix match between the bearing and housing is what caused the bearing failure.
so I was wondering if anyone knew much about the difference between the 00-02 axle bearing and the 96-99 bearings. And since I have the 02 bearing housing can i just use the newer bearing or should I replace the housing and use the 97 bearing?
