Rear Axle Lube Change Surprise
sabre65
Changed the rear axle lube and found a couple of small pieces on the magnetic drain plug. Appears to be pieces of a roll pin or spring retainer? The biggest piece is about 1/4". I haven't any noises or issues but thought I would change the fluid and didn't expect to find anything other than normal wear debris. Any thoughts on what this is from?
:dammit:
