Rear axle / wheel bearing recommendations / part numbers??
98Fizzy
Read somewhere on here that nachi and koyo are like re-boxed oem bearings and about half the price.. but can't find part numbers for them.
Any and all help is greatly appreciated.
Edit to add: 98 RWD with ABS if it makes a difference.
Prolly also going to need the retainers that are 42423-20010 need 2 not sure if your has the abs toothed ring or not but its 43517-35010 need 2
Beck Arnley makes them too....you can get them from Rock Auto. Not sure of quality, but they're very reasonably priced compared to the others.
Thanks brothers. If I can get the toothed ABS ring and the retainer off with a press and spliter without damaging them.. I could just press them back on after putting the new bearings in right?
Or would it still be a good idea to at least put new inner retainers?
Found the KOYO bearings.. $68.19 each
90363-40020 - Toyota Parts Deal
ABS Ring.. Amazon says it wont fit but this site says it will.. $43.32 each
43517-35010 - Genuine Toyota ROTOR, SKID CONTROL, REAR
Retainers.. $15.59 each
42423-20010 - Toyota Parts Deal
BECK/ARNLEY @ Rock Auto.. $30.79 each
More Information for BECK/ARNLEY 0513350
Amazon has em too.. $35.80 & FREE Shipping on orders over $49
https://www.amazon.com/Beck-Arnley-051-3350-Bearing/dp/B000CAXV9A
This NSK should be accurate right? Say's it fits. $29.41 & FREE Shipping on orders over $49
https://www.amazon.com/NSK-W0133-1836172-NSK-Wheel-Bearing/dp/B001T9HNWO
I got the Timken branded bearings from rockauto. They are labeled NACHI and made in Japan! They come with the retainers too.
Just wanted to verify; I ordered 2 Timken sets (1 for each side) and they are indeed NACHI branded from Japan. The retainers are also NACHI but say made in Brazil. ;o)
How is the machining on the Nachi retainers you got? When I got mine I noticed they weren't as good as the OEM ones (had nicks and the surface wasn't as well polished) so I just re-used the OEM ones.
The bearing do look OEM, that's the same as what I've used twice.
If you're good with a press you can re-use the ABS ring and one retainer ring with no issues. The shop re-used those both times but did destroy the other retainer ring both times. So make sure wherever you buy them from has a return policy so you can get your money back!
While you're working on your rear differential this is a good modification for the breather. I've had problems with my '98 and '99 4Runner rear axle oil seals leaking until I did this.
4Runners.org - Type R Rear Differential
I was just looking into this. I changed my gear oil 2 weeks ago & yesterday it started leaking on the rear PS. I'm gonna do the Breather Extension Mod & see if it stops leaking. The original breather has never been replaced so I'm pretty sure it's clogged with dust & dirt. If it keeps leaking...well I'm screwed then.
Just an FYI: You can get the c-clip out if it's groove and slid up under the abs ring.. then press the whole shebang off the axle in one shot. I just did both of mine and it was better than cutting (cutting is wasting money).
The Retainers are great looking and stamped. The ones I removed must have been aftermarket because they had no markings on them. One seal was all rubber and the other was something like stock but who knows.
I flipped retainers and set at 4mm.
Doubt I'll have any issues for a long time now.
This is how I did it although I replaced the inner retainer but your way is fine because that outer retainer get no wear whatsoever.
Cutting also could possibly groove the axle causing a leak under the inner retainer if the groove is in that area.
Yeah, I replaced the retainers (both because each bearing came with 2 retainers) and seals and the o-rings for the flange.
Need to replace my axle seals and figured I should probably do my bearings while its apart just wondering if anyone has ever used the kit that marlin crawler sells specifically the one I linked. It looks like it comes with everything I need except the ABS ring and the second retainer can those be reused or should I find them somewhere else?
https://www.marlincrawler.com/axle/rear-axle-parts/rear-axle-service-kit-1979-99
That's a great price. OEM parts. Everything you need. You can reuse the outer retainer and the ABS ring if you press them off, which is the right way to do it.
7ron
