Rear bumper options
4RFritz
I’ve searched threads for over an hour, so figured it’s time to post. I need to find a rear bumper and tire carrier. The Victory 4x4 bumper looks good, but what other options are there? If there’s a good bumper forum I’m missing, happy to delete my post!
Thanks for sharing. I like that one for a minimalist look, but the tow hitch receiver looks funky to me. I will check out the others mentioned.
I had the victory one put on basically as soon as it came out. Drove all the way up to their shop and had them bolt it on even. So far, I love it. I needed to upgrade my rear springs to the Icon Overland ones because the bumper + 33 inch rear tire + dual swingouts is about all the factory springs can handle. I've had no rust issues outside of some surface rust around the hitch receiver (I swear those things come pre-rusted), no squeaks and no issues with the locking mechanism.
A few problems I did have:
The bolt to hold on the camera/license plate relo kit wasn't stainless. I figured that out after a midwest winter when I went to rotate the tire and had to grind off the wing nut.
Be sure you are positive on your rear light selection, once the bumper is in I don't see a real easy way to get them out.
Remember, 33 inch tires are heavy. Having them a few feet off the ground means you are going to have to armstrong that thing on and off when you need it.
That's really about it. It's been a solid upgrade and I have no regrets.
Did you ever consider reading the Consolidated rear bumper thread in the Modification sticky above near the top?
I looked through the consolidated threads and did not see that one. I also searched all threads using the search field for about an hour and on more than one occasion.. then finally posted this because I couldn’t find what I needed.
Do you have link you can share for the consolidated rear bumper thread? I’m probably just passing over it like an idiot.... but I did try to find it there, but just saw front bumper stuff.
I posted it up above. #5
AndiGarage
