atcpup
You can always buy a bottoming tap and clean the threads up yourself. You shouldn’t have to, but it’s easier to buy them already coated than to get them coated yourself. Pretty sure the banjo is M10x1.0, but verify that before cutting any threads. Use some grease on the tap to catch the shavings and blow the hole out with air to remove the rest.
After a bit of research, most 94-98 Cobra calipers are M10-1.0 fine pitch thread (some 99's use this too) Ford went to the M10-1.5 course thread for the later years. Folks are just going to have to check and confirm. This is the problem that I believe kramer03 may have had.
