Rear Hatch Question
Mtn.Rush
If someone gets the chance and you have the rear spoiler installed can you go and open the rear hatch and look on the left and right upper corners for me. Arent there supposed to be plastic covers on the two holes (one on each side) where the bolts are to secure the spoiler down?? Or do you see the bolt heads? I could of sworn there were covers there at one point but I had my rear hatch re-painted due to the TSB for the rear trim (where the key hole is) rubbing on the liftgate and causing it to flake off now I just see the bolt heads. I found some on google but no real clear close ups. On one it does look like there should be gromits covering the bolt holes, so Im 99% sure im not losing my mind and there was something there at one point.
Passenger side
Driver side
TerryNap61
