Rear Mount Turbo exhaust
Is this possible. To plumb an self contained oil system for the turbo.
Using the electric pump, pump oil out of a storage tank, through a cooler into the turbo back into the storage tank.
You could use super expensive synthetic oil, it would last a long time because there would be no contamination,Pre pressurize the turbo before spinning and run a timer so it would cool down yet not leave the truck running.
It would also keep potential junk from the engine getting into the turbo bearings.
It would also keep potential lines from being ripped out offroading.
We thought about doing this with clownmeats runner but found that you would either need 2 pumps or you would have to bring the turbo low enough to get the res high enough to gravity feed.
Why would you need two? Would there not be enough pressure to push the oil up once it passes through the turbo? What if you put the pump just downstream of the turbo, and then put the reservoir on the other side of the pump. So it would act by pulling the oil after it passes through the turbo, then pushing it into the reservoir, and as the reservoir filled it would continue to cycle through?
man i keep coming back to this, its awesome! is it safe for the turbo to go through water though?
Sure, as long as the intake and charge pipe are 100% sealed.
People ask me this all the time on my youtube channel, if it was a race car and the turbo was right off the manifold and glowing red I wouldn't spray it with cold water but in this application it's fine. My truck has been through water/snow for over a year and it's fine. My Honda has a turbo hanging out of the front bumper right off the manifold and hasn't cracket or exploded driving through storms and such.
1. A turbo needs oil pressure. A scavenge pump can supply this but not suck it out at the same time, it will not pressurise the reservoir.
2. There isn't enough room to have it gravity drain into a reservoir, I built one and it just wouldn't fit.
3. Therefore to have its own oil system you would need two pumps, one to feed the turbo and one to return it up to the reservoir, unless you don't go offroad and don't mind a reservoir hanging down about 4" lower than your frame.
Can you post pics on how it is sealed?
I already went through and added all the same components as yoter on eBay. I have a welder so should be able to weld up a pipe. If not I will just buy one from him.
The turbo itself is not sealed, there is just a hose that runs from the inlet of the turbo to a rear snorkel. go through clownmeats build thread and see.
curious if you or clownmeat ever got any real world MPG number after the turbo install? looking at building a 4runner here in the next 6 months and this is a definite part of my build considering i live in the southern oregon area where we have some of the steeper interstate 5 sections.
Also have you guys done any, or plan on doing any dyno runs?
Yoterman87, sent you a PM about buying a pipe from you. I also am wanting to do this, but with no lift. I'm going to have to figure out how to route the charge pipe to the engine bay. I've already got the turbo laying in the garage. I'm looking forward to the extra power for when I'm towing boats during the summer.
I really haven't noticed too huge of an increase just about a mpg or 2. but you need to run premium after turboing so cost isn't much different. I'm sure I'd do a little better if I kept my foot out of it. lol. but it's fun stomping on all the wanna be street racer Honda's around town. :)
we haven't dyno'd and don'treally don't know when we will since there isn't one anywhere close to us.
This is a great thread @Yoterman87.
I'd really be interested in this, my only concern would be the water. There are occasions, living in the PNW, when I have no choice but to drive through a couple feet of water, snow, what have you. For me, aesthetically, a rear snorkel is not an option. My intent with my 4Runner was a nice looking everyday vehicle, that's off road capable. I personally think the rear snorkel kinda kills that.
Do you think there is really any other option to the rear snorkel?
some people were suggesting making box inside the truck above the turbo.
youngrk
