Ok picked up some 3m tape as small width I could. The next quisten is weather to use it on one side or the other and or both? As we all no there is limted space when installing in channels. My thoughts are to remove the old existing ones and clean off all glue and use the new 3m on one side and install roll up windows and let the tape hold them without rolling down the windows so a few days.
I have the same issue with one of my rear Weathertechs. The tape you show has a foam core & is probably too thick & may cause the window to reverse when closing. The thin stuff should work though. I believe that's what the factory uses, but I'm going to contact Weathertech on Monday. Maybe they can send me se few feet of the stuff.
-Randy
-Randy
My question has anyone had this problems with in channels vent visors before any brand? I just don't get why they want go up into the channel of the factor weather stripping in the rear as well as they did on the fronts. Any ideas, tips or comments are welcomed. My wife does not want the 3m ones she only wants the in channel.
Thanks for any other help or new help you can pe
