Rear Wash/Wipe Problem.
Zulu95
Hi,
I just had my 2005 T4R Limited delivered last night and have found that the rear wash/wipe does not work at all. Is this a common problem? I did search but found nothing that pertained to this problem. I did check fuse #38 and it is good. My next thoughts are a faulty column switch or the wiring loom or the rear components.
Not a happy camper!
Check and make sure the back window is rolled all of the way up. I'm pretty sure that none of the rear door functions (window, wiper, defrost, spray) work if the window is even slightly cracked open.
ryanbt Thank you, thank you, thank you. I was just about to make an idiot of myself with the dealer but your solution was spot on.
Now I need to learn the rest of the quirks buried in the manual! There is a definate learning curve here and so much more than our old (15 years of faithful service) V8 AWD Explorer Limited we traded in.
Thank you again!
Deelock
