rear window black weather strip
wyattroa
Does anyone know the part number to this? The black stripping the outlines the window on the outside? Mine is coming undone on one side and I am trying to find a replacement since I dont want rust and its winter here.
Robert
Along the bottom of the window or top & sides?
The piece along the passenger side does not reach the bottom of the window anymore. The black piece curves about an inch before it should. Can you replace just one piece or is it wise to replace the whole thing?
Robert
side window weatherstripping
If you have one going, I'd replace all four plus the rear hatch.
I've replaced all of mine and it takes a couple of minutes for each window. The only tool is an allen key and they run less than $20 each.
www.partznet.com is one of the best prices/service
Part Numbers
Weatherstrip Assy, Front Door Glass, Outer LH: 68162-35060
Weatherstrip Assy, Front Door Glass, Outer RH: 68161-35060
Weatherstrip, Rear Door Glass, Outer: 68163-35030
Weatherstrip, Liftgate outer: 68290-35031​
what I think I am needing is piece number 2 in this diagram..
2004 TOYOTA 4RUNNER Parts - Conicelli Parts Center
Here is a picture of the back window, you can see on the right side where it doesnt reach all the way down.
mail.jpg~original
So that part is $95, but it looks like it does not include the bottom section. Is my assumption correct?
Spendy part, but it is better then getting rust..Thanks that was the part I thought it was, just need verification. I ordered that and the bottom strip, might as well replace the entire back area..
Robert
Robert
I just wanted confirmation that the part identified does not include the bottom section (at least by looking at the picture, that is my assumption). I was confused by some earlier posts indicating it was the only part required to replace the whole rubber seal around the rear window.
What is the part number for the bottom section? I need to order that as well.
No worries, I had to deal with all this when I replaced my weatherstripping too. Good thing for this forum!
I hear ya about it being Friday... guess that's why I'm browsing T4R.org instead of engineering things like I should be lol
Replaced the bottom weather seal lift gate
Just replace the bottom weather seal of the lift gate window. The part was cheap, $28 and replacement only took 5 -10 minutes. My old weather strip dried and was falling apart. Every time it rain water goes in the door and leaked out the holes at the bottom of the lift gate.
During the winter the lift gate would freeze and would not open. Now that it's fix, less water would go in the door.
2007 4runner SR5 rear window rubber weather seal
I saw this thread on the links seem to be outdated. I need to replace the whole bottom weather strip seal....i have a 2007 Runner.....does anyone have a more recent web site to recommemd...I couldnt find a thread on 07 runner for this topic. Thanks in advance.
Hi....i saw your post for your 08 Runner on the rear weatherstrip replacement. Can you share the site you used to get your parts. I have to replace the whole bottom strip and the outer seal...i had rust in door so the went in and replaced it but tore up the bottom seal and strip. Thanks for any help or info.
