Rear window Molle. Which brand tightest fit to window?
My only problem with these racks, somebody correct me if I'm dumb, is that they don't seem to go up to match the top of the window. Maybe it's an optical thing, but, if not, itd be nice to see one that did.
Sent from my S61 using Tapatalk
I have the Rago panels and shelf, I have several Rago pieces and have been really happy with them for both my 2010 and 2020. Customer services is amazing.
Here's a pic after I finished the install.
I bought the Rago panels, and they sit pretty close.
If you are going to use MOLLE pouches you would be better off putting them on with the panels out of the vehicle, especially around the top and center, because you are not going to get you hand behind the panels.
I see this comment a lot, but don't understand it. I have the Rago panels, and you are right they sit very close.
I install and remove my MOLLE bags all the time with zero issue. You don't need to put your hand behind the panel to lace a MOLLE strap. Drop it behind and pull it through where you want it with your finger.
In all seriousness, this isn't an issue at all.
I’m interested in the panels, but at the price point I’m not sure I want or need them that much. I could get the remaining RCI skid plates for what the 3 piece rago set goes for. I’m certain the skid plates are worth it...
Your small hands might be why you don't have an issue.
That, or you buy cheap pouches with flimsy straps.
All my pouches have stiff straps that don't flop down when installing them.
I am intrigued by Victory Off-Road molle panels only because they have an interior basket you can add to them to divide the cargo area in two. Getting all 3 is expensive though.
Victory Off-Road Basket
Their basket pretty much eliminates using large pouches in conjunction with the panels because it bolts up in the middle of the panels.
But it's nice to see so many options on the market.
