Recommendations on preventive maintence at 200K?
nghiS4
I'm at 199,501 miles today & did an oil change. I keep a spreadsheet of maintenance I do; there may be a few things I forgot to add as I went along. Mods not listed. Take a look & let me know if it seems I may have missed anything, but for the most part I try to do more than what's recommended. My ownership began 135,432 on 4/1/13 (2nd owner), so the notes prior are dealer notes direct from www.toyota.com/owners. The first owner did very regular maintenance at the dealers.
Sorry if it's hard to read, I simply copied & pasted from my spreadsheet.
Mileage Date Service Location Notes
15,316 May 28, 2005 15,000 MILE SERVICE Toyota 101, Redwood City, CA "Lube, oil and filter change; inspect and adjust brakes, rotate and inspect tires; set tire pressure; top off fluids; Inspect the following: air filter exterior lights, ball joints/covers, brake lines/hoses, automatic transmission flu
20,093 Sep 30, 2005 20,000 MILE SERVICE Toyota 101, Redwood City, CA "Perform lube, oil and filter change; rotate tires; inspect front and rear brakes; perform multi-point inspection; set tire pressure; check and top off fluids. FUEL INJECTOR CLEAN.
25,119 Jan 26, 2006 25000 MILE SERVICE Toyota 101, Redwood City, CA
30,377 Jun 10, 2006 30,000 MILE SERVICE Toyota 101, Redwood City, CA
35,619 Nov 4, 2006 35,000 MILE SERVICE Toyota 101, Redwood City, CA
40,545 5/17/07 40K Service Toyota 101, Redwood City, CA
45,986 11/11/07 PASS CAR 15K BASIC, (4) WHEEL ALIGNMENT, DIAGNOSIS Dublin Toyota
50,787 3/15/08 TRUCK/SUV 5K BASIC Dublin Toyota
56,393 8/23/08 AS PER CUSTOMER REQUEST PREFORM EXPRESS LUBE PLUS OIL AND FILTER CHANGE, 19 POIN Dealer not found
61,281 12/6/08 @MW PERFORM 60,000 MILE INTERVAL """"BASIC"""" TRUCK SERVICE AS PER ATTACHED MEN, RELINE FRONT BRAKE Dealer not found
66,632 4/18/09 CUSTOMER REQUEST 5,000 INTERVAL TRUCK SERVICE AS PER ATTACHED MENU UP TO 5QTS(EA Dealer not found
71,066 8/29/09 5K BASIC SERVICE, STEERING Dublin Toyota
75,398 1/23/10 OTHERS, OTHERS, 15K INT VAL, AIR FILTER Dublin Toyota
77,875 4/20/10 SMOG Toyota 101, Redwood City, CA
80,282 7/3/10 OTHERS, OTHERS, 5K INT VAL Dublin Toyota
85,345 12/18/10 Others, LOF, Rotate tires Dublin Toyota
90,670 7/18/11 OTHERS, OTHERS, OTHERS, 90K INT VAL, DIAGNOSIS, 2003-2009 4RUNNER Dublin Toyota
97,734 9/17/11 Others, LOF Dublin Toyota
97,752 9/19/11 Others, Tire repair Dublin Toyota
104,398 12/14/11 Others, LOF, Rotate tires Dublin Toyota
111,294 3/10/12 Others, LOF, Rotate tires Dublin Toyota
112,772 4/12/12 Others, SMOG, Battery Replacement Dublin Toyota
118,274 7/8/12 Others, LOF Dublin Toyota
126,772 11/9/12 OTHERS,*6 IN ONE,*EXTERIOR LIGHTING,*BRK FLD EXCHANGE,*AIR FILTER Dublin Toyota
133,702 3/8/13 Used car safety check Toyota Walnut Creek
135,432 4/1/13 Transmission Drain & Fill Home Toyota Type IV ATF
135,500 4/6/13 Power Steering Drain & Fill Home PS: Oreilly's Premium ATF
135,510 4/7/13 COOLANT, F+R DIFFERENTIAL,TRANSFER CASE DRAIN/FILL Home
135,565 4/9/13 CLEAN THROTTLE BODY & MAF SENSOR, DELETE HC FILTER Home
136,400 4/25/13 Spark Plugs Changed Home NGK
142,756 8/13/13 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
146,361 10/22/13 Lifetime Front Brakes Brake Masters, Elk Grove, CA Bendix Front Ceramic Brakes
153,940 5/12/14 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
166,500 3/15/15 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
175,000 12/19/17 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
185,000 7/20/16 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
193,668 2/24/2017 Oil & Filter Changed Home Mobile 1 Synthetic 5w-30 High Mileage
196,250 5/11/17 New Dashboard (recall), BST SMART STOP TECH*software update Toyota Elk Grove
196,942 6/7/17 Coolant Exchange Toyota Elk Grove Toyota Super long life coolant
197,000 6/10/17 Transmission Drain & Fill Home Toyota Type IV ATF
197,500 6/14/17 Power Steering Drain & Fill Home PS: Oreilly's Premium ATF
197,997 7/5/2017 F+R Differential & Transfer Case Fluid Change Home Mobil 1 Synthetic Gear Oil 75w90
198,300 7/13/2017 Spark Plugs Changed Home NGK
198,851 7/27/17 Brake Pads Lifetime F+R, Fluid flush Brake Masters, Elk Grove, CA Ceramic pads
199,501 8/8/17 Oil & Filter Changed, Greased LR UCA’s Home Mobile 1 Synthetic 5w-30 High Mileage, NLGI #2 grease
According to his "signature"/permanent info at the bottom of his reply box, he doesn't have the V8, the V6 has a timing chain that for the most part lasts a very long time!
+1
V6 chain is pretty much good for the life of the engine... you basically never have to do anything. Really great motor.
I rolled over 200k not too long ago...
Aside from oil and filter(s), not much on the engine side... All I did was spark plugs, serpentine belt, all fluids, diffs, TC.
Dashboard recall? I just picked up a 2005 v6 with a January build date, and didn't see a recall on the service record. I'll find out when they replace the front left wheel bearing this weekend.
Depending on your vehicle I've included greasing my door hinge sliders to keep them freely moving. At some point I need to pull the door panels off to grease the window gears.
