I just bought 2 pro comp lights and this wiring harness:
Amazon.com: Explorer Pro Comp 9301 Single Mini Switch Kit - 2…
which shows relays in the pic, but did not actually come with a relay and the diagram for wiring on the back of the box shows no relay, just battery to fuse (which was provided) to switch, and then from switch out to lights.
Also, the fuse that came with it has a red wire that loops around and is attached at both ends of the fuse case (there are 2 of them in the pic, but mine only came with one-I think that pic is for more than 2 lights). Do I cut this loop and attach wire to it from battery and the to switch and does it matter which end goes to the battery?
Thanks for any help!
