Relay Pin-out diagram needed - relay part no. 90987-02012
HiluxSurf SSR-G
Senior Member
Hi,
I've been trying to get the pin-out diagram of relay p/n 90987-02012 (Denso 156700-0870). however, i'm seeing, from google, different pin-out diagrams for the same relay.
Does anyone have an official/validated pin-out diagram of this relay?
Edit: The relay and the socket doesn't have the pin numbers.
Hi,
It looks like a standard micro-Bosch relay:
Now, as to the pin numbers in a specific relay application, there is no law mandating that Toyota number them the same way in every application. So, to be certain, I would need the vehicle spec and the exact circuit use the relay is in.
For example, that p/n is used as the EFI relay on a 2000 V6 4Runner, and the pin-out for that application is shown at the bottom of page 22 of the attached. That is the official pin-out for that application in that vehicle. (Note: In this relay, the center pin of the three pin row 87a (normally closed) is not present.) Hope this helps. If you are using a Toyota EWD, just refer to the section Location of Relays in the same EWD manual.
Thank very much!
It's for the fog lights of a 2000 4Runner. I'm using the Toyota EWD but didn't look at that page! :doh::embarassed:
patnewton
