Remin Interior Kit??
Pretty much looks like an overlay with double sided tape. Over time the corners/edges will lift much like other similar products, trapping debris underneath. I'd save your money on something else, or wrap it in Di-Noc. It's a little more time intensive to do so but overall the install will be a lot cleaner. I guess the trade off is that the Remin kit is real CF as opposed to just a sticker.
I remember seeing this (or similar to it) on a 5th gen very early on in the parade, and it seemed pretty jacked up looking....I'd be sure you see one before purchasing and installing
That does not sound good and is the reason I wanted to see some real photos.
I messed around with a bit of leftover dinoc I had on a complex dash piece last week or so. It is tricky to get it to lay correctly. I was interrupted and it is still laying on the workbench....
Just wanted to see if there was a better solution.
I bought a dash kit for my Tundra and was immediately disappointed by how cheap it looked after I installed it. I ended up throwing the kit in the garbage and spray bombing the dash with Krylon satin black. I'm happy with how it turned out and will likely do the same with my 'Runner.
Zett
