Removing driver side dash panel under steering wheel
BCKGUY
Sorry if this has been asked before. Trying to install Gentex mirror and running wires down to fuse box. Unable to remove panel under steering wheel on dash. I removed the bolt on bottom right. Did not see any other bolts. Do I need to pull harder? How many clips hold that piece on? Any extra info/pics/links to other posts appreciated. Thanks!
Yes a little more to removing the panel...
Per a post from [MENTION=78273]Jeremy556[/MENTION]
Remove the little plastic screw to the left of the dead pedal, then pull the kick panel out. Then there are 2 bolts along the bottom edge of the panel, release the hood release cable. Then it is just push clips holding it in place, pull straight outward.
You may have to remove the panel to the left of the stereo where AC knob is, not sure if model matters or if there is clearance.
Unhookmthe battery before messing with the under steering wheel airbag. When I take the dash apart tomorrow Ill try to document it.
You have to remove the doorsill panel and the kick panel on the driver side before you will see the second screw. Also, be sure you removed theAC knob cover on the driver side too. After that, it's just clips.
goddesszilla
