repiping a house
There are also recirculation pumps with a push button. It's a round, white, lighted button that looks like a button for a door bell. I've seen those with an optional remote control. Just wake up and aim it at your master bath, and you'll have hot water by the time you walk in there.
I'm still not a fan, though. Some people don't like running the water for a minute or so. My way of thinking is that the water will get treated and reused. The coal that was burned to power the pump is gone forever, and we don't have 200 million years to wait for more. That and the higher chance of leaks add up to no pump for me.
That's a great point. When I use my shower I kick it on, let it run while I'm tending to other business. By the time that's done, water is hot. Now my master bath lavatory faucet I have timed. It takes over 5 minutes to get hot water unless of course I've been running the shower or bathtub.
On top of that some of those retrofit pumps are well over $500 and I just can't justify it. I've been in this house over three years and have just come to live with it.
I like your point about energy that's something my customers ask about and I tell em yeah it will use electricity but now I can add your point. What part of TX are you?
You could probably make the argument that the energy used to get that water cleaned and back into the system outweighs the cost of recirculating the water. Not saying it is, just a thought.
... What part of TX are you?
Austin area. I work for a company in Austin.
Odd coincidence WRT this thread: I went to a house a few days ago for a bid to repipe a whole house. I had been there 6 weeks ago for a slab leak/reroute. My repair was their third or fourth slab leak. No leak this time. They want to go all PEX overhead before a remodel with hardwood floors. Stop a leak before it starts.
No pump, but unknown cause for leak. We don't repair lines under the slab. Just reroute overhead. Found the manifold pretty easily. Cut open wall in garage opposite worst buckling in dinning room laminate floor. Old cuts & couplings on lines coming up from floor.
The boss says no jackhammering slabs. Apparently a bad experience before I started working there. Can't say I disagree, though. Much less destructive/disruptive to just go overhead from the manifold.
Yeah my old boss did not repair leaks in slab. Cap at manifolds, reroute with Pex overhead. Definitely less intrusive to patch sheet rock and paint than flooring, concrete etc.
BTW I'm in Pflugerville. Maybe we'll run into each other at supply house!
I was always told that yes, repairing the point at which the leak is occuring will work fine, but there is a higher likelyhood of additional leaks after that. The pressure or stress will exacerbate on all the old pipe/fittings as new leaks are fixed. Just what I've always heard.
repipe
my last home was completely repiped, it had polybutelene piping (quest) with acetal fittings and aluminum crimp rings. i qualified for a free repipe under the class action suit filed against eastman corporation. i'm also retired from the plumbing industry. i'm old school and really like copper but pex plastic has alot of advantages.
