Replace brakes, now they are squeaking when coming to a complete stop
5th Gen Brake info
This is what I’ve got for my 2010, newer models may vary.
I also attached two version of Toyota Brakepad replacement guides.
Brake Parts
Front Rotor 4351260191
Front Brake Pads 0446560320
Front Shim kit anti-squeal: 0494560090
Front Caliper Pins: 4773560300
Front Caliper Pin hold (Spring): 4774360280
Front Caliper Springs (fitting kit): 0494735050
Front Anti-Rattle Spring: 4774835010 (not needed if using fitting kit?)
Rear Rotor 4243160311
Rear Brake Pads 0446660140
Rear Shim Kit: 0494660141 / 0494660140
Rear Caliper Fitting kit: 0494722050
Toyota Rubber Grease: 08887‐01206
Toyota Brake Shim Grease: 08887-80409
Do Not Use - TM kits
Torque specs:
Front brake caliper mounting bolts: 91 lb-ft (17mm)
Rear brake caliper mounting bolts: 77 lb-ft (17mm)
Rear brake caliper slide pins: 65 lb-ft (17mm)
Bleeder tubing: 1/4” ID
What is a TM kit?
Thank you and your son for all of your help.
I'm somewhat newer to Toyotas, this one just turned 100K but thankfully has been pretty straightforward to work on.
Does this site have a preferred etailer to order these parts?
straight forward and lots of room to turn a wrench..
thadjay
