Replaced Brake Cylinder Assembly, VSC OFF, VSC TRAC and Slide Indicator On
ebanky1
My '05 4runner is a little over 60KM, I recently had to replace my Master brake assembly, pretty expensive. After I changed it, I still have the VSC OFF, VSC TRAC and Slide Indicator On. Very annoying after how much I spent. The dealer I need to change the sensor. Not sure I believe him anymore! Does anyone have any idea on what the problem is?
Did you change the master cylinder, or did the dealer? A wheel sensor sounds likely. Changing the master cylinder would mean bleeding the wheel cylinders at each wheel, perhaps a wheel sensor was bumped or unplugged by accident? I'd look at the wires running to the hubs where the wheel rotation is sensed, one of those sensors could be unplugged or wires damaged. Also look for a connector unplugged at the master cylinder or at the ABS unit. On my old Land Cruisers the wheel sensors would get dirty (they were magnetic and would attract rust and shavings), cleaning them helped.
